SST k-omega convergence
Old   June 9, 2008, 12:09
Default SST k-omega convergence
mauri
Hi! I'm simulating a diffuser augmented wind turbine using a SST k-omega model. Residuals of continuity, turbulent kinetic energy and velocity decrease rapidly, but residuals of omega are stable (I mean really fixed on a constant value) on a higher value. Why? What can I do? I've got no problems with k-eps models (and the same mesh)
Old   June 16, 2008, 06:59
Default Re: SST k-omega convergence
Wiebe
Hello Mauri,
There are a few things that you can try to do. What works really depends on your situation (mesh, steady sate or transient simulation, boundary conditions, etc.)
- try to do some iterations while solving the turbulence equation only.
- lower the relaxation factor for omega, or, if it is really low, try increasing it.
- adapt the mesh to the gradient of omega.
Good luck! Wiebe.
Old   June 20, 2008, 08:45
Wiebe
Hello Mauri,
Ironically I had the same problem the past few days. I didn't want to look up turbulence levels for the input boundary condition, so I set it to zero until i would. It turns out that the SST k-omega model doesn't like 0 for both k and omega as inlet boundary condition.
Hopes this helps for you too.
Wiebe.
Old   June 20, 2008, 13:37
mauri
Hello Wiebe,
I tried to run some simulations and thanks to your advice things are better, in terms of convergence rate. And of course another problem has arised: when I refine mesh in order to use enhanced wall functions with y+<5 (using adapt menu in fluent, both in conformal mode and in hanging node), then I get a non-physical solution, even starting iterations from a previous solution (which seems correct)!
Sorry for still bothering you...and thanks a lot!!!
y+ for k-omega = 30 ??? Ralf Schmidt FLUENT 3 May 20, 2006 17:28
K-omega Amir FLUENT 5 November 22, 2004 09:46
k-omega Amir Main CFD Forum 0 November 18, 2004 03:05
k-omega Chetan Kadakia FLUENT 2 September 1, 2004 17:05
B.C's for k and omega Suppe Main CFD Forum 5 January 14, 2002 10:18
