plane slider-bearing analysis
Old   July 3, 2008, 11:35
Default plane slider-bearing analysis
Masoud a h
I am modelling a plane slider bearing in 2d using GAMBIT. The solution is done using FLUENT 5 solver.
The problem I encounter is what are the boundry condition of this problem because i used the perssure inlet and pressure outlet and then the flow reversed ?
Flow Analysis tilting Pad thrust bearing using CFX julien CFX 5 April 9, 2014 08:38
Bearing and air simulation R.Escartin CFX 1 December 12, 2011 07:03
UDF for air gap in a foil bearing Rishikesh FLUENT 0 September 22, 2008 01:12
Air bearing dinesh rakwal FLUENT 0 July 2, 2004 17:38
how to get bearing coefficients satish g.v CFX 0 November 7, 2003 05:21
