radiation transfer between solid and fluid zone |
August 13, 2008, 12:45 |
Dear all,
I'm modeling a radiation problem by using DO model. I have a fluid(air) zone in adjacent to a solid(silicon) zone. I select to couple two walls between them, and I also select "participate in radiation" for solid zone. (1) So how is the energy transferred between these two zones? (2) since i only want to model radiation, not the heat conduction, I choose the set the thermal conductivity of air to a very small number so as to only allow the radiation transfer. I also set a very small thermal conductivity of solid substrate so there're no heat transfer inside it. When I've done the simulation, I found in the contour results that the "incident radiation" uniformity is different from the "temperature". Do you have any idea how this happens? Regards Thomas |
How model radiation of both solid wall and fluid£¿ | Harry Qiu | FLUENT | 2 | February 3, 2013 23:04 |
heat transfer between solid and fluid | Devy | FLUENT | 4 | June 4, 2010 00:28 |
rotating solid zone with heat transfer | Sasha | FLUENT | 1 | March 24, 2009 16:55 |
Fluid-Solid Heat Transfer | Charles Pringle | CFX | 6 | March 4, 2007 16:16 |
solid fluid iteration plus radiation | harish | Main CFD Forum | 1 | January 30, 2006 04:28 |
