Pressure Boundary Conditions
Old   September 26, 2008, 12:15
Default Pressure Boundary Conditions
John S
I'm new to Fluent and have run into a problem with mass-specified pressure boundaries that I can't seem to resolve. Specifically it seems that for the case that I am running, Fluent will run fine for first 50 iterations or so. After that the pressure in my domain suddenly explodes, with a high of around 14.5 million psi and a low at an equal negative number (one half the domain will be the high, the other half will be the low). Has anybody encountered such a problem before or have any idea why it's doing what it's doing?
Thanks, John
Old   September 30, 2008, 01:01
Default Re: Pressure Boundary Conditions
Prasad
For this, in CFD, the solution is said to be diverging. You may like to reduce under-relaxation factors. Don't forget to check the case for appropriateness of models you've selected in case you're using Fluent 6.3.
Pressure boundary conditions hiras FLUENT 22 July 27, 2015 01:38
Pressure Boundary Conditions Dave FLUENT 2 June 8, 2009 17:05
Pressure boundary conditions Vijay FLUENT 2 January 14, 2009 12:24
Pressure boundary conditions Lionel S. Main CFD Forum 1 August 24, 2007 18:03
PRESSURE BOUNDARY CONDITIONS Max MEBUG FLUENT 2 August 17, 2007 00:42
