virtual volume in Fluent
Old   October 2, 2008, 19:57
Default virtual volume in Fluent
kartik
Hello!
I would like to know if fluent can handle virtual volume associated with real and virtual faces.
I have made a flowvolume for an airplane model. but the volume is virtual. Can i compute the flow over the model in fluent.
Thanking you regards Kartik
Old   October 2, 2008, 22:30
Default Re: virtual volume in Fluent
solver-issues
when you export mesh to fluent, it does not know whether you created it from real or virtual. it would work fine.
Old   October 3, 2008, 08:06
doki
yeah I think so too! if you can generate a mesh in the domain, so you can export it too!
Old   October 7, 2008, 18:07
kartik
Thanks you for themessage. I am able to import the mesh file. the mesh file has 53 skew elements. and when i do the grid check in fluent, it says that it is perfectly allright. I gave the velocity inlet of 80 m/s sec. after 40 itterations. when i try to see the flow on the symmetry plane. it shows there is no velocity. gives the result of 0 velocity all over the flow.
I would be glad to recieve reply from u
Old   October 8, 2008, 03:03
doki
that is rather a problem related to fluent. it is better the mesh not to have skewed elements.
Old   October 10, 2008, 07:11
Prasad
I guess you are using symmetry plane. Please specify that BC accordingly.
convert virtual volume to a real one djalil FLUENT 0 January 22, 2009 15:07
virtual or real flow volume for wind tunnel? qm FLUENT 1 January 9, 2009 15:26
VIRTUAL VOLUME Sean Cody FLUENT 1 March 17, 2006 02:25
how to solve this error for virtual volume annie FLUENT 1 November 3, 2004 08:15
Virtual volume Saturn FLUENT 1 September 29, 2004 19:13
