Pressure drop?
Old   October 23, 2008, 09:40
Default Pressure drop?
Munni
Hi folks:
I have a simple question: We have to design a component, and the customer said the pressure drop has to be 2kPa (for example). Now what he means, is it static pressure or total pressure? Because if the diameter of the inlet and outlet are same, then we will not see any static pressure drop. My question is, if some one say pressure drop is A amount, does he/she means static or total pressure drop? How does that work in industry environment?
Munni
Old   October 23, 2008, 11:13
Default Re: Pressure drop?
AS
hi Munni , for your question about the pressure drop usually it referd to only (Pressure Drop)without mention to be dynamic or total ,As no work done on/by the system then there is no change in the static component ,for example let consider a pipe with length (L) as fluid (x) pass thru the pipe it will have a pressure drop (y) this pressure drop is mainly caused by friction caused by pipe surface roughness which will effect the Dynamic component of the fluid(V^2/2g) so i think you can mention this pressure drop as a (dynamic or total )but not static.
AS
Old   October 24, 2008, 00:36
mAx
report/surfaces/Area Weighted Surface of Total Pressure pressure drop= total pres.(inlet) - total pres. (outlet)
Old   October 27, 2008, 11:11
Munni
Thanks you folks for your comments.
Old   March 25, 2010, 14:21
rofluent
Rohini is on a distinguished road
@ Max... would it work for multiple inlets & outlets too??
Rohini is offline   Reply With Quote
What type of pressure can give the pressure drop david FLUENT 1 February 17, 2014 11:51
Pressure Drop Gabriella FLUENT 1 October 14, 2008 06:43
pressure drop siddiqui FLUENT 2 March 15, 2006 06:13
pressure drop margaret mkhosi FLUENT 1 January 17, 2006 06:45
pressure drop shan Siemens 4 January 15, 2006 01:59
