CFD of Aircraft Wing
Old   December 26, 2008, 12:29
Default CFD of Aircraft Wing
sashankh
I have done the analysis of a 3D wing geometry in fluent. I need to see the downwash created by the air flow. can someone pls tell me how i can see this? also is it possible to see a video of the flow over the entire wing?
Thanks!
Old   December 30, 2008, 01:21
Default Re: CFD of Aircraft Wing
zongtwi
I think you're better off not using FLUENT Post-processing capabilities. Try using other programmes such as EnSight. FLUENT post-processing capabilities is not good to say the least.
Hope that helps.
Old   December 30, 2008, 03:45
Anastasios
i would better suggest to use tecplot 360 for post-procwssing. You can see videos and many other thinks much easier than ensight!
Old   January 3, 2009, 01:38
Sashankh
sorry for the delay.
thanks a lot for the tips on postprocessing!
Looking for an aircraft wing model........ mimi FLUENT 4 May 28, 2007 04:36
Looking for a standard aircraft wing model........ mimi Main CFD Forum 3 May 21, 2007 13:26
Looking for an aircraft wing model in FLUENT mimi Main CFD Forum 0 May 10, 2007 04:03
Modeling Aircraft-Inlet-Wing interface Riaan Main CFD Forum 0 August 26, 2005 11:45
Aircraft wing modeling serhat kilerci FLUENT 0 January 13, 2001 14:51
