October 28, 2019, 01:42 |
DPM problems
Evan Huang
Rep Power: 9 |
Hi
I am now dealing with DPM model in Ansys Fluent, and I set up the correct mass flow rate for my particles but the number of particles tracked which showed on the console has a big difference from what I have calculated. I want to ask why? and How to maintain the correct particle number in the flow domain? injection type : surface injection particle velocity : 6 m/s particle diameter : 55 micron continuous phase time step size : 3*10^-5 s mass flow rate : 0.000508 kg/s size of inlet surface : 0.006912 m^2 particle treatment : unsteady particle tracking & track with the fluid flow time step according to my calculation, the particle number should be around 15000~18000, but after the simulation, the no.particles tracked showed around 2 million. -------------------------------------------------------------------------------------- Updating solution at time level N... done. Injecting 1653 particle parcels with mass 1.524e-10 at t = 0.70368 Advancing DPM injections .... number tracked = 2925478, escaped = 1666, aborted = 0, trapped = 0, evaporated = 0, incomplete = 0, incomplete_parallel = 0, coalesced = 1 ---------------------------------------------------------------------------------------- please help me to figure out this. Thanks a lot! |
February 26, 2022, 17:09 |
menoufia
Rep Power: 5 |
did u figure out the cause because I have a similar problem !!!
April 9, 2022, 16:11 |
Ontario
Rep Power: 4 |
I have the same problem and it seems the particles do not evaporate. Did u figure out this problem? |
April 10, 2022, 00:48 |
Hello masi,
Unless you give some information, its hard to get help from here. Try to post some screenshots of your evaporating species, boundary settings, and observe the DPM related quantities by contour plots for the mean values. Sometimes if diameter is quite higher (10^-4), then the evaporation will not be appropriate. So, go with Rosin-rammler diameter distribution and set: Max, mean and min dia as 10^-4,10^-5,10^-6 or calculate the diameter ranges using formula as described in user guide Some other below links may help you. https://forum.ansys.com/discussion/2...es-evaporation https://www.youtube.com/watch?v=6CggFyAsDwI https://www.researchgate.net/post/Sa..._DPM_in_Fluent Thank you |
April 10, 2022, 10:24 |
Ontario
Rep Power: 4 |
Hello Kummi,
Thank you for your help. I modeled spray in the open air. DPM Model: nozzle: solid-cone / multi-component/ inlet velocity of nozzle 90 m/s / Rosin-rammler min: 1.2e-6 and max 50 e-6 / angle: 10 / radius : 0.165 boundary condition for open air : pressure-inlet 0 / pressure-outlet 0 boundary condition for nozzle : inlet velocity 90 m/s / trap in nozzle wall and escape other walls |
April 10, 2022, 13:32 |
Hi Masi, it looks like continuous phase is dominating the discrete phase. The reason why evaporation s not happening. It's just my guess.
Interaction with continuous phase is ON ? Try to give conditions such that discrete phase should have enough residence time to react. Inject particle time step ~ reduce it and check. With pressure inlet = 0, what is the velocity calculated at the inlet, if then the velocity at the main inlet is reasonable ? Boundary conditions is the key. And how about the mass flow rate of the injection. All your parameters need to be appropriate and if they are physically reasonable your case will work. Use various trail and error methods. Check as many references. I'm sure u can find your way. Try giving high mass flow rate as a trail case, so there might be a chance for evaporation to happen. Feel free to ask further. Thank you |
November 29, 2022, 05:33 |
DPM problem
widad
Rep Power: 4 |
I used DPM model in fluent for particles injections, the problème that i have is the particle keep moving in solid phase ( cause i have 2 phases the first is liquid and the second is solid ( solidification active)), now i want to stop the particles when they arrive to the solid phase ( velocity = 0) by UDF but i don't know which function can do that ( read the liquide fraction depend on the particle posiiton, then if the fraction is 0 update the velocity to 0) Please if someone have a solution could help me Thanks |
Dem v.s dpm? | Amir1 | Main CFD Forum | 1 | November 3, 2019 09:52 |
Confused between DPM and multiphase flow | pchoopanya | FLUENT | 0 | June 21, 2019 04:44 |
[ANSYS Meshing] Periodicity problems in icem | zeeshu | ANSYS Meshing & Geometry | 0 | April 17, 2016 20:59 |
Problems when compile SU2 v4.X with openmpi | BopngMa | SU2 | 1 | September 6, 2015 06:30 |
slow after mesh for enhanced wall treat DPM | joshkemp | FLUENT | 0 | May 1, 2007 17:20 |
