How do I compile a UDF from a .c file?
Old   January 15, 2009, 16:16
Default How do I compile a UDF from a .c file?
Travis
I'm very new to UDFs, and I have a .c file that I borrowed from someone. I don't know how to compile it.
Can someone point me in the right direction?
Old   January 16, 2009, 00:10
Default Re: How do I compile a UDF from a .c file?
Davy
you need a c compiler and set the correct compiler environment as the compiler prespecified.
Old   January 16, 2009, 00:33
Travis
I understand the basic concept... a pointer to a compiler would be great.
Old   January 28, 2009, 11:39
KJ Larsen
Hello Travis
Fluent can compile UDFs, but it has to be launched from the command prompt if you're using a windows machine. Select the .c source file and press Build and Load (Define -> User Defined -> Function -> Compiled...)
There will definitely be more info in the UDF Manual or this forum. Kris
UDF compile warning: no newline at end of file mrt FLUENT 4 December 5, 2007 04:48
compile of udf ashraf Main CFD Forum 1 March 15, 2007 15:05
Compile the UDF Eric FLUENT 7 August 18, 2006 14:46
Error when compile UDF file Lee FLUENT 4 May 3, 2005 06:52
compile the UDF Li Jingping FLUENT 2 April 14, 2003 21:18
