Time derivative
Old   February 18, 2009, 08:24
Default Time derivative
Dmitry
Hi. I want to calculate dp/dt (static pressure time-derivative) in my transient calculation and store it. Is it possible to access to pressure value at previous time step in UDF?
Old   February 18, 2009, 09:27
Default Re: Time derivative
Grzegorz
Yes, it is possible. You can use C_P_M1(c,t) or C_P_M2(c,t) for previous and second previous time step, respectively (see User's Guide - 3.2.3 Cell Macros). You can also use memory storage C_UDMI to save current pressure field and in next time step acces to it and refill it with new values. Hope this help.
Old   February 19, 2009, 13:48
Dmitry
Thank you. But the problem stil remains. I use C_UDMI to save previous time step pressure: C_UDMI(c,t,0)=C_P_M1(c,t) in my UDF in DEFINE_ADJUST macros. I get error message: FLUENT received fatal signal (ACCESS_VIOLATION) after first iteration.
Old   February 19, 2009, 13:50
Grzegorz
Did your solution is calculated or did you start it from very begining?
Old   February 19, 2009, 14:09
Dmitry
Yes, my solution calculated some time steps. Firstly I did 5 time steps without using of C_P_M1, then I put it in my UDF, reinterpreted it and tried to run calculation. But I have error.
Old   February 19, 2009, 14:17
Grzegorz
Send me your udf - kondora@imc.pcz.czest.pl
Old   February 20, 2009, 07:54
mange
did you remember to allow memory access for your C_UDMI ?
/m
Old   February 20, 2009, 09:27
Dmitry
What does it mean /m? I use other C_UDMI(c,t,1), C_UDMI(c,t,2) and so on to store my variables and I have no problems to access them.
Old   February 20, 2009, 09:33
mange
I mean in the panel of user memory you have to specify how many fields you want to allocate memory for. by default it is 0.
the derivative of Scalar on time ? owen FLUENT 0 March 5, 2009 04:59
Second Derivative Swarup FLUENT 0 June 7, 2008 06:21
Time derivative in transiente run Antonio Lopes CFX 2 January 12, 2008 11:03
Derivative and double-Derivative for steep functio Kali Sanjay Phoenics 1 March 27, 2006 07:51
how to obtain time derivative soubhik CFX 1 August 25, 2004 23:43
