CD too high
Old   February 17, 2009, 09:19
Default CD too high
Matthew
i am completing an analysis of a 2D aerofoil in Fluent, i have checked all my reference values and BC values such that the operating conditions are those found at a speed of 0.53 Mach at 20,000ft. i am using the k-epsilon viscous solver and the CL values calculated correlate well with documented data at around 0.6, however the CD values are in the region of 3*10^-2 which seems an order of magnitude too high??? especially when i compare it to other CFD runs i have done in other packages. my supervisor seems to think its something to do with the turbulent length scale, but im not sure what to do. any ideas??
cheers
Old   February 21, 2009, 04:42
Default Re: CD too high
Shivakumar
are u setting Cd or Cl from the first run? if so dont do that..... run without drag settin for atlaest 400 iterations and then set the cd monitoring..
High Value of HTC Daniel CFX 4 October 20, 2008 18:01
Why temperature is so high? Albert FLUENT 2 June 22, 2003 11:28
How can it b possible? Flow from low p to high p?? Chris FLUENT 5 January 28, 2003 06:29
about high Y+ Hannah liang CFX 0 August 27, 2002 16:34
High-Order FVM David Young Main CFD Forum 2 February 27, 2002 03:44
