Hydrogen-Air Non-Premixed Combustion
Old   February 21, 2009, 15:24
Default Hydrogen-Air Non-Premixed Combustion
Wasim
Hello there, I am working on simulating hydrogen-air non-premixed combustion. I am having problems in attaining good results. My set-up includes a jet of hydrogen at 900K (to allow for auto-ignition) flowing into a still enviroment at 300K (working fluid by default - air). I have modelled the problem using non-premixed combustion model. The contours of static temperatures does not show an increase in temperature; in other word, I cannot see the flame (which tells me that combustion does not take place). I have even tried patching the fluid to a temperature of about 2000K, but nothing seems to work out. Please help me out! The deadline for the work is due in for the 3rd of March, 2009. I would really appreciate your help.
Thanks
Old   February 22, 2009, 15:01
Default Re: Hydrogen-Air Non-Premixed Combustion
Ev
Hi Wasim,
I am working on the similar problem of nonpremixed combustion, but the fluids are air and methane. I just started my project and I am a beginner in Fluent. Could you please tell give me an idea that for nonpremixed combustion, what viscous models and other parameters do I need to select?
Thank you so much.
Old   February 22, 2009, 16:14
Wasim
Non-premixed combustion model in fluent is most suitable for turbulent diffusion flames. Hence I suggest you start off with k-epsilon standard model and have the default values for k and e (which is 1). Those are the value I chose anyway. The modelling process is quite straight forward, but i am just stuck because ignition does not seem to take place in my place. Anyways Good luck!
Regards,
Wasim
Old   February 22, 2009, 17:03
Ev
Hello Wasim,
Thanks for replying.
Old   February 23, 2009, 13:20
Allan Walsh
Are you using the built-in reaction mechanisms? What values are you getting for kinetic reaction rate? turbulent reaction rate? You can modify parameters if needed to get combustion started. The basic k-epsilon model for turbulence combined with eddy dissiptation model for combustion will not give a lot of insight into the flame structure, but should at least show something burning.
Old   February 23, 2009, 20:59
Wasim
Since I was using non-premixed combustion model I do not have the choice to specify reaction mechanism. However, my simulation is now working and I think I have obtained good results (though I might be wrong). Thank you!
Regards,
Wasim
Old   March 21, 2012, 04:44
tsram90 is on a distinguished road
Originally Posted by Wasim
;156811
Regards,
Wasim
How did you correct this problem?? I am also having constant value for pressure and temperature
tsram90 is offline   Reply With Quote
Old   February 5, 2013, 03:27
deepthi
deepthishan is on a distinguished road
Use k-e model but try giving turbulence and hydraulic diameter in boundary condition instead of giving values for k and e
deepthishan is offline   Reply With Quote
Old   June 13, 2013, 03:48
Bahram
bahramnourani is on a distinguished road
;156764
Thanks
Dear Wasim
I define the excess air of fuel by selecting a suitable mass flow of air at the boundary condition of the Fluent software,but I see that by increasing the excess air of fuel the maximum temperature is increased!??
I expect that the adiabatic flame temperature is dropped down by increasing the excess air of fuel.
Please guide me that how can I define the excess air of fuel at the non premixed combustion model.
Thanks
Bahram
bahramnourani is offline   Reply With Quote
air-hydrogen combustion steven FLUENT 0 August 15, 2008 17:06
Hydrogen combustion Subramani Siemens 0 March 9, 2008 23:52
hydrogen combustion A.Subramani Siemens 1 December 1, 2007 19:05
hydrogen combustion George Main CFD Forum 17 August 1, 2007 10:15
Hydrogen Air combustion in a combustion chamber popi CFX 7 July 11, 2007 18:40
