Any body help me!, Impeller simulation problem.
Old   March 5, 2009, 11:12
Default Any body help me!, Impeller simulation problem.
Desperado
I have the problem regarding to radial flow close type impeller of water centrifugal pump, for many time I tried to run by single blade with periodic flow k-epilon reslizable, single domain rotaion with 2900 rmp and structed hex mesh type ,simple scheme and the others by second order upwind, but the results is still not convergence both mathmatics, physical and also reverse flow appeared at the outlet pressure.
Any body is expertise in this field please help me, I will send the Case and data files via email for discuss the problem, thank you for your kindly.(thomas_crown20@hotmail.com)
Old   March 7, 2009, 13:06
Default Re: Any body help me!, Impeller simulation problem
Sa
I have very good expereince in turbomachinery CFD. Send your cas and dat files at my email id.
Regards
Old   June 9, 2009, 13:04
Smile
Genesis760 is on a distinguished road
Hi everybody.
I have the same problem with a simply 3D geometry with an impeller in it. I want to see a good velocity profile but i don't know how to set a proper boundary condition. Can anybody help me? Tnx
Genesis760 is offline   Reply With Quote
Questions on an impeller simulation with Fluent Angelo D'Ettore FLUENT 4 July 7, 2010 10:08
Sample simulation of axial flow impeller in a duct Vashishth CFX 1 November 16, 2008 19:34
simulation of centrifugal impeller Txema FLUENT 1 February 23, 2007 01:08
TASCflow - Impeller Simulation Centaur_ks CFX 2 May 27, 2003 12:02
Problem about 3D blunt body high Re simulation David FLUENT 0 September 27, 2002 10:59
