March 17, 2009, 20:27 |
Error: 1000000: Failed to allocate
Nishikant
hi,
i am trying to read case and data files. case file is around 100MB and data file is 200MB. While reading data file i get this error message. Error: 1000000: Failed to allocate 59.53MB memory (..\..\src\amgif.c:884) Error Objects: () My laptop has 3GB RAM and more than 50GB free in Hard disk. I am using windows vista: home premium. What may be the reason. thanks |
March 18, 2009, 15:55 |
mike smith
I think the problem with the processor it self it can not handle big files (big mesh volume),since Fluent is a numerical solution method solver it needs a processor with higher capability
1.reduce the mesh size 2. I would try first with Pressure Based solver 3. parallel method or supercomputer |
March 18, 2009, 21:09 |
Nishikant
Thanks for the reply.
I am using Intel Core 2Duo T6400 processor in Dell Studio1435 laptop. Thanks |
April 11, 2009, 18:13 |
bilquise
I am trying create grid interface between two walls and after certain number of wall I get the following error creating wall-230-shadow creating wall-235-shadow creating wall-239-shadow creating wall-243-shadow creating wall-248-shadow Warning: ST_Realloc: out of memory.realloc_storage: unable to realloc node, size 72068448, t 178, myid 1000000. Warning: ST_Malloc: out of memory.realloc_storage: unable to realloc node, size 72068448, t 178, myid 1000000. creating wall-253-shadow Warning: ST_Realloc: out of memory. Error: Resize_Storage_On_Thread: Out of memory. Error Object: () Please help Thank you Bilquise |
October 7, 2013, 15:08 |
#5 | |
M.P.
Hello, I experienced a similar issue, except that I've been running the same job on the same computer, and I experienced this error after restarting in Windows. Restarting windows again and deselecting some of the transport equations didn't solve the problem. Changing the problem from double precision to single precision did the trick...this makes sense since memory requirements plumet. |
March 26, 2022, 14:39 |
Failed to allocate memory
r3act0
Hi everyone
So I recently changed my solver method from pressure-based to density-based and even with 64 ram I am getting this failed to allocate memory error and have not been able to solve it in a week. Any idea on how to proceed? Thank you in advance. |
[blockMesh] Error buffercc117assertion failed | hungerturm | OpenFOAM Meshing & Mesh Conversion | 1 | September 5, 2007 04:20 |
Failed to allocate memory. | Tufsen | FLUENT | 0 | February 26, 2007 10:28 |
Error: Could'nt allocate fine level coeff matrix | Khan | FLUENT | 1 | July 7, 2006 01:44 |
Error: Failed in Fill_Domain. | sawa | FLUENT | 5 | January 17, 2005 03:34 |
Proam ERROR:Could not allocate more memory | Erika | Siemens | 10 | November 16, 2004 20:42 |
