Changing k-e constants to functions
Old   August 18, 2009, 16:59
Default Changing k-e constants to functions
tstorm is on a distinguished road
Hi all,
I'm working on a user-defined v2-f turbulence model for FLUENT (I know it has one, but I'm trying to make one with curvature correction.)
The model uses the standard k and e transport equations that the k-e model uses. The transport equations are the same, but the constants are different. In particular, the C_1e constant is different.
For the k-e model, C_1e = 1.44
For the v2f model, C_1e = 1.4*( 1 + .05*sqrt( k/v2 ) )
Does anyone know how to change the C_1e constant to a function?
Thanks in advance.
tstorm is offline   Reply With Quote
Old   August 19, 2009, 12:59
Ok, I figured out how to add an additional source term to the epsilon term (DEFINE - BOUNDARY CONDITIONS - FLUID - SOURCE TERMS). I coded my source term, added it as S_e in the epsilon transport equation, and set the C_1e and C_2e constants to 0 in the DEFINE - MODELS - VISCOUS menu.
Now I have another question. I can't figure out how to change C_1e and C_2e using text commands. Is that possible?
Correct values for constants k E in wall functions jaswi OpenFOAM Running, Solving & CFD 0 February 21, 2008 11:33
Wall functions tutlhino OpenFOAM Pre-Processing 0 July 2, 2007 05:04
changing model constants in k-e turbulence model Sunil CFX 3 October 3, 2006 12:12
User-Defined Functions Boisson FLUENT 2 January 18, 2002 22:09
N-S equations:divergence free functions? D. Puigjaner Main CFD Forum 1 July 27, 2000 12:43
