August 28, 2009, 08:59 |
Problems with gambit mesh
Emanuele Leoni
Rep Power: 17 |
I need your help with gambit because i'm not able to create a right mesh. I start from the beginning. I'm a beginner using fluent and gambit too. I need to create a mesh that is a section of a burner, so the grid has to be a kind of rectangular and meshed gradually. The grid is a 2D grid because then in fluent i'll use the axialsimmetric property and in this way i'll be able to process the simulation. I created the mesh in this way. First i created the points, then I created the edges and finally I created the plane inside the edges. Then i meshed the edges and then i meshed the inside part. I think it is all right. Then I exported my mesh in *.MSH format and then I tried to read the case with fluent. The problem is that if I open a 2d section of fluent, i get this message: "Error: File has wrong dimensions (3). Error Object: #f" If I start the 3d section the result is: " Reading "C:\Users\lions\Desktop\PROVA2.msh"... 55 nodes. 40 mixed wall faces, zone 2. Error: no cells in zone, id = 0, ind1 = 1, indn = 0Reading Cells: failed while reading section 12. Clearing partially read grid. Error: Read aborted due to critical error. Error Object: () " I think the problem is that I have to declare that the mesh is a 2d mesh, but I don't know how to make it. Could someone help me please? Thank you very much Emanuele |
August 28, 2009, 12:44 |
Troy Snyder
Rep Power: 18 |
When exporting the mesh, in the dialog box to specify file name, there is a check box that must be activated to flag the mesh as 2d.
Export 2-D (X-Y) Mesh This may solve your problem. |
August 28, 2009, 19:05 |
Emanuele Leoni
Rep Power: 17 |
Yes, it works. It was so simple.....
thank you very very very much, now i can start with the simulations. Emanuele |
Gambit - Mesh Problem for a complex 3D geometry | Nelson | FLUENT | 3 | May 28, 2012 06:57 |
Successive Mesh in Gambit | ashish | FLUENT | 0 | April 28, 2006 00:42 |
How to mesh a circle by Gambit? | Zhengcai Ye | FLUENT | 5 | March 24, 2006 01:04 |
error when mesh in Gambit | icestar | FLUENT | 2 | October 28, 2004 14:11 |
3-D Mesh Check in Gambit..... | SHR | FLUENT | 4 | March 25, 2003 03:10 |
