October 7, 2009, 04:03 |
Which type of BC would be most suitable?
Stuart
Rep Power: 25 |
I'm setting up a simulation for transonic flow over a ramp which has a finite surface behind it. The image shows basically the domain with the boundary conditions and flow direction. What is the best boundary condition type to have downstream of the flat surface? I though maybe Symmetry but in real life the flow over the lower surface (which I'm missing out to keep is simple) would not make the flow here symmetrical. Hope some one can help., Thanks Last edited by siw; October 7, 2009 at 04:35. Reason: Typo |
October 7, 2009, 12:16 |
Rep Power: 17 |
I think your best bet is to model the whole domain. But if you can't afford that, I'd try pressure outlet or outlet.
Pressure instability with rhoSimpleFoam | daniel_mills | OpenFOAM Running, Solving & CFD | 44 | February 17, 2011 17:08 |
Flow Around a Cylinder | ronaldo | OpenFOAM | 5 | September 18, 2009 08:13 |
LiftDrag tool | nuovodna | OpenFOAM Running, Solving & CFD | 45 | September 2, 2009 17:56 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
