how to decrease time simulation??
Old   October 7, 2009, 05:02
Question how to decrease time simulation??
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Dear All,
I'm running airfoil simulation. but it takes much time. i wanna make less time to simulate. I wanna make simpler meshing. To take less time simulation.
What should I do??
THX
teguhtf
teguhtf is offline   Reply With Quote
Old   October 7, 2009, 12:18
tstorm is on a distinguished road
Can you post your mesh?
tstorm is offline   Reply With Quote
Old   October 7, 2009, 12:38
Post
teguhtf's Avatar
teguh hady
Hi tstorm
Could you give me your email??I'll send you soon.
THXS
teguhtf
Old   October 7, 2009, 13:47
I'd rather not post it on the forum. I don't want to get onto any more spam lists than I'm already on. I'd be happy to email you if you post yours, or if you post a few pictures of your grid I can try to help.
Old   October 7, 2009, 14:36
Philipov's Avatar
Svetlin Filipov
Philipov is on a distinguished road
The only one effective way to reduce computational time is.... more computational power - more cores, domain partition.... the reducing the mesh may lead to not convergences... be careful if you are planning to reduce the number of cells...
Philipov is offline   Reply With Quote
Old   October 7, 2009, 15:32
Felipe Gutiérrez Donoso
Figd84 is on a distinguished road
You can try another pressure velocity coupling that fits better your problem. Also try to use higher URF´s to achieve higher convergence speed, but be careful, since your problem can diverge.
As Philipov said, the only noticeable way to improve simulation time is more computer power.
Figd84 is offline   Reply With Quote
Old   October 7, 2009, 16:44
There's much more that can be done than just computing power. The turbulence model, UR factors, courant number, grid density, residual smoothing, timestep, multigrid controls, etc. can all affect convergence, and if we knew more about the case setup we could try to help you choose the right settings. Send me a private message with your email and I'll try to give some tips.
Old   October 7, 2009, 16:59
But diferent turbulence models and grid density could affect the solution accuracy.
The mesh should be fine enough to avoid results variations between one mesh an a coarser one. And the turbulence model usually is chosen because the problem´s own nature (reading papers and experimental data).
Old   October 7, 2009, 17:04
You're right. If he's already using the right turbulence model, there's nothing we can do to help in that case. But if it's a simple external aerodynamics problem, for example, and he's using an RSM model, we could cut processing time and use the SA model without sacrificing accuracy. Or, maybe the first gridpoint is in the laminar sublayer, which isn't necessary for the SA model. Or, maybe cell growth is so small that cell count is unnecessarily large. My point is we can help a new FLUENT user by giving real tips instead of vague pointers.
Old   October 7, 2009, 17:08
That´s right. I´m just being pesimistic .
Anyway, what are multigrid controls?? I haven´t done anything with that.
thanks
Old   October 7, 2009, 17:21
Ha, ok.
FLUENT uses an algebraic multigrid for implicit solutions, and a full-approximation multigrid is an available option. The most commonly changed option is the cycle type (V or W), but there's plenty of other things to play with. Theoretically, the FAS multigrid is better for non-linear problems.
Old   October 7, 2009, 17:26
hmm... interesting.
Thanks
Old   October 7, 2009, 22:54
Lightbulb
  #13
teguhtf's Avatar
teguh hady
Hi Guys!!!
Thanks for your response!!
Here is my email
huget_teguh@ymail.com
time dependent source using DEFINE_SOURCE T81 Fluent UDF and Scheme Programming 5 February 28, 2011 17:23
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
time step for unsteady film cooling simulation Janendra Telisinghe FLUENT 0 December 11, 2007 06:14
time of a simulation Z FLUENT 2 March 29, 2005 04:29
