Urgent! how to plot contours without grid in the figure?
Old   November 9, 2009, 18:44
Default Urgent! how to plot contours without grid in the figure?
Ivan
ivanbuz is on a distinguished road
I need some contours plots by tomorrow, and I am going nuts right now.
the plots are to show z-vorticity. I know how to plot z-vorticity contours in Fluent, but I don't want grids to show in the figure. I did not select item "Draw Grid" or "Filled". How can I get rid of the grid in the figure?
Thanks a ton!
ivanbuz is offline   Reply With Quote
Old   November 9, 2009, 20:14
Ivan
anybody can help? I have searched the whole forum, and I am trying everything I found without luck.
Old   November 9, 2009, 20:27
Cool
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Hello ivanbuz
To solve your problem try this step
1. open contour window
2. deselect "Filled" in contour option
3. click display
4. open your contour window again
5. select "filled"
6. Click display
I use FLUENT 6.2.16 for my example
Hope it helps
teguhtf
teguhtf is offline   Reply With Quote
Old   November 9, 2009, 20:42
Ivan
Teguhtf,
Thanks a lot for the reply. I tried and it did not work. did I miss anything?
after step 6, the figure is just a normal figure of filled contours. What I want is basically a plot with 20 iso-surfaces each with different iso-value and different color.
I use version 6.3.26. I am not sure if this is the reason.
Old   November 9, 2009, 21:28
Red face
teguhtf's Avatar
teguh hady
I'm sorry. I think you'll draw ordinary contour. For iso surface, you can see an example of annulus in
http://www.fluent.com/software/sf_me...s/tutorial.htm
Hope it helps
teguhtf
Old   November 9, 2009, 22:00
herntan's Avatar
YH Tan
herntan is on a distinguished road
to show the ISO surface, u will need to have rendering light turn on i think.
Herntan,
Add Reputation if I am right
herntan is offline   Reply With Quote
Old   November 9, 2009, 22:21
Ivan
Teguhtf and herntan,
Thanks for being kind enough to reply!
After several hours of trying, I have found the way to do it. I will post the solution here when I get things on hand done, maybe tomorrow.
Old   November 9, 2009, 23:04
teguhtf's Avatar
teguh hady
You're welcome. Post it to this forum, please!!
thanks
teguh
Old   November 10, 2009, 17:36
Ivan
Solution, as promised:
1. Generate a serial of iso-surfaces. Easy to do using text commands like below (this generates only 1 surface which includes 20 iso-surfaces)
surface/iso-surface/z-vorticity
z-vorticity-isosurface
-2.2266e+005
-2.0817e+005
-1.9368e+005
-1.7919e+005
-1.647e+005
-1.5021e+005
-1.3572e+005
-1.2122e+005
-1.0673e+005
-92243
-77753
-63262
-48771
-34281
-19790
-5299.5
9191.1
23682
38172
52663
2. display--contour. select the generated iso-surface, check "filled", and uncheck "global range".
3. use light to get 3D effect. use rotate to get the angle you want.
final figure will be like this
Old   November 10, 2009, 18:16
teguhtf's Avatar
teguh hady
Hi!!
Congratulation!!
Nice to see your simulation. By the way, can you send me .cas & .dbs file??
I wanna learn about that. here is my email huget_teguh@ymail.com
Thanks a lot
teguhtf
Old   November 10, 2009, 21:39
Default nice
  #11
sai ram
sairam is on a distinguished road
hi ivan ur 3d stimulation looks gud can u tell me how did u remove de grid for counters, i had tried it but no result
and can i have ur file it looks intresting
satmuri@student.ysu.edu
thank u
sairam is offline   Reply With Quote
Old   November 10, 2009, 21:44
herntan's Avatar
YH Tan
Very nice image u got... Gratz..
its pretty interesting how u create 1 surface by using 20 ISO.
I never know it can be done that way.
Thank Ivanbuz.
Herntan,
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 03:33
coloured grid lines instead of contours Matthias FLUENT 8 December 10, 2008 19:09
Vorticity plot in grid refinement study CH Main CFD Forum 3 May 22, 2007 12:35
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 11:18
