November 26, 2009, 12:20 |
Fluent 2D Nozzle Simulation
Harry Mandilas
Hello all,
over the past 10 days or so I have been trying to solve a 2d nozzle simulation in Fluent 12. I ve tried all viscous models, both with default settings and decreased under relaxation parameters but all my attempts either failed to reach < 10^-3 ish residuals or gave me some odd results. There are three pressure inlets (left top, bottom and centre) and one pressure outlet. I have attached a few pictures to help you help me.. As you can see the model is perfectly symmetrical (double checked) and the mesh is quite fine (or so I believe).. However, all the simulations that did converge suggested flows that were convected towards one side of the nozzle (please see pics). Any suggestions on why this odd convection occurs??? Thank you very much for your time.. Harry |
November 26, 2009, 12:37 |
Shengyi Wang
I am not sure what it is in your case, but sometimes the solution is physically asymmetrical even with symmetrical boundary conditions
November 26, 2009, 12:52 |
Harry Mandilas
Thanks for sharing your thoughts gmwsy..
The funny thing is that I ve also tried several different nozzle geometries with various Ae/Athroat values and I still get the same results... |
November 27, 2009, 05:38 |
Maxime Perelli
Rep Power: 41 |
There is a turbulent phenomenon (Coanda effect) where the stream flows on a side, instead of remaining axial (symetrical), but in your case the max residuals <1e-3 sounds to indicate a non-converged solution.
Also the Mach-Number distribution is quite weird (max velocity should be at the minimal section), but as you are in transient and compressible solver, I won't comment your result (because of 0-experience). From my own experience (inconmpressible flow), I had sometimes convergence troubles with Pressure-inlet/Pressure-outlet combination. Try to switch Pressure inlet with velocity inlet, and reiterate.
In memory of my friend Hervé: CFD engineer & freerider Last edited by -mAx-; November 27, 2009 at 12:52. |
November 27, 2009, 12:04 |
Nozzle
Andy Robertson
Sonic line seems to be at throat so thats ok.
Flow will accelerate in expanding section but if nozzle is over expanded peak mach will be "inside" nozzle with seperation down stream. Given coarsness of mesh away from center line that separtion would not be well predicted, numeric issues might start it asymetrically, then grid / numeric issues could take over. I do LOTs of converging diverging nozzles. Mostly I use GASP, Fluent is last resort. Make sure you are using the coupled solver and started first order for a while before going second order. Good Luck - Andy R |
November 27, 2009, 17:14 |
Harry Mandilas
Max and Andy,
thanks to both of you for your replies. The early separation "inside" the nozzle was purposely seeked for.. I have tried both the coupled (density based solver) and pressure based solvers with the same unsuccessful results. Have always started first order and then onto second order.. I assume that Andy's comment suggests a better meshing away from center line (and early inside the diverging part of the nozzle). I ll try that... I ll also try using a velocity inlet as Max suggested. As for using GASP...well, I must first learn how to use FLUENT and then persuade the boss to get a license for another package... Thats a toughie... Just for the record, I have now managed to get a "symmetrical" result using an axisymmetric approach. However, I am a bit worried about the validity of such an approach as I will be trying to actually construct this thing and make it work for real... I ll get back if I have any better luck Cheers again for the help... |
December 1, 2009, 05:51 |
hie
can sumbody provide me with a tutorial for -
1] modelling of flow thru an orificemeter ( i am especially interested in meshing..as i have a constraint of 10000 nodes for the total pipe) 2] how shuld i go abut solvinf in fluent..?? |
March 26, 2010, 22:18 |
#8 | |
Guite
The nozzle supersonic condition can not be reached. |
March 27, 2010, 09:36 |
#9 | |
Shengyi Wang
Hi Harman, What do you mean by same results? According to my experience, it is usually not easy to get converged solution with both pressure inlet and pressure outlet. Maybe you can try to use velocity inlet and see if the results will be improved. If it is the case, then the problem is the boundary condition rather than your mesh or model. Good luck. Shengyi |
January 11, 2012, 14:25 |
#10 | |
anush
plz plz could you reply fast, million thanks |
October 26, 2012, 08:24 |
dimensions
#11 |
Sami
will u please tell me where u get nozzle dimensions any refrence plz???
fluent, nozzle |
HELP - Moving car simulation in fluent | Brad Wells | FLUENT | 7 | January 4, 2018 19:55 |
Solid Rocket Nozzle - Fluent 5 Tutorial Guide | Ijaz | FLUENT | 4 | April 2, 2015 20:46 |
Nozzle flow simulation in inviscid and viscous | Cath | FLUENT | 0 | January 28, 2007 02:16 |
compressible flow in a counterflow nozzle | d.vamsidhar | FLUENT | 0 | November 24, 2005 01:45 |
New Fluent Remote Simulation Facility | Paul Bemis | FLUENT | 8 | July 2, 2002 09:18 |
