to set the axes in 3d in contour plot
Old   January 13, 2010, 19:58
Default to set the axes in 3d in contour plot
shailendra pandey
shailendra is on a distinguished road
hi ,, friend , i am doing project on three phase flow in fluidised bed reactor ,,
unsteady , state in 3D
my problem is to set the axis x,y,z such that
z axis is cylindrical column vertical height
x axis along horizantal radial
y axis is perpedicular to screen of computer
in analysis i am getting ,,contour plot in x and y plane ,,,and z axis is perpendicular,,inside so it difficult to rotate every time and view the contour in Z-X ,plane
how i have to set this axis so that in contour plot , i will get Z-X plane ,,,and Y axis be inside the plane of computer
i am using Fluent softwere 6.2
shailendra is offline   Reply With Quote
Old   January 14, 2010, 01:03
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
display/view
If no pre-saved view enable to display what you want correctly, you may create your own view and save it (diplay/view, option camera...)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   January 15, 2010, 01:21
-mAx-'s Avatar
Maxime Perelli
you can also translate and rotate your mesh, so that the axis matches what you want:
*Grid / Rotate...
*Grid / Translate...
[Tutorials] Tutorial of how to plot residuals ! wolle1982 OpenFOAM Community Contributions 171 February 20, 2024 02:55
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Contour plot Magnoli CFX 4 November 21, 2007 09:16
Pro-Vis Contour Plot Chris P Siemens 1 November 16, 2004 23:16
contour plot of stream function liu FLUENT 6 August 19, 2003 22:30
