Target-mass-flow-rate:CONVERGENCE PROBLEMS
Old   March 3, 2010, 06:01
Default Target-mass-flow-rate:CONVERGENCE PROBLEMS
sarav is on a distinguished road
I'm modelling the flux over an airplane and I'm modelling the mass-flow outlet in the air intalke of the motor using the bc:
-pressure outlet+target mass flow rate
The flux is compressible (M=0.8)
I've great convergence problems: the solution is not converging AT SECOND ORDER and in addiction to this the simulation goes on very slowly.
Can you help me?
How can I solve this problems?
thanks!
sarav is offline   Reply With Quote
Old   March 3, 2010, 15:26
mems21 is on a distinguished road
I'm making a cavitation analysis in a valve so there's high speed and i also have problems of convergence.
What i would suggest you is
- start being totally sure about your viscosity model
- calculate an initial solution with first order convergence
- decrease tolerance so that you will get a more accurate solution
- start changing to second order but step by step (first pressure and continue with the others) till you see which one gives you problems
Maybe you can modify something by knowing where you have problems to converge.
Also use a coarse mesh to start so that the problem is not the mesh.
I hope i can help you
mems21 is offline   Reply With Quote
Old   March 3, 2010, 15:50
Hi mems,
thank you for your reply!
One fast question, first of all:
you use for your simulation a positive or a negative gauge pressure for the pressure outlet (with target mass flow rate?)?
If the reference pressure in the aerodynamic field is 0 Pa, and if I use a positive gauge pressure air will "try" to get into the field, right? And so if I want air to go out from the domain I must set a negative gauge pressure, it's right?
thanks!
sara
Old   March 3, 2010, 16:02
Gauge pressure is always difficult to know the behaviour.
i'm using 0 Pa for both Mass Flow Inlet and Pressure Outlet, cause my domain is the valve, I have no aerodynamic field.
I'm still checking my boundary conditions so i cannot help you with this.
Sorry,
mems
Old   March 3, 2010, 16:04
Thanks for your reply!
You are kind!
I try to open a new tread and ask for this question...
Bye and thanks
sara
Running dieselFoam error adorean OpenFOAM Running, Solving & CFD 119 February 1, 2016 14:41
Mass Flow Rate Error jallison FLUENT 1 May 16, 2011 16:22
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 05:44
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 17, 2003 19:23
