y+ values for DES
Old   March 19, 2010, 02:06
Default y+ values for DES
CFT
CFT
CFT is on a distinguished road
Hi all
As far as I understand the DES uses RANS model at the boundary instead of wall function. However I notice in the results of the turbulence there is a y+ term. Can someone explain ?
thanks
CFT
CFT is offline   Reply With Quote
Old   March 19, 2010, 02:13
denizen is on a distinguished road
rans models at boundary works as usual (with and without wall function) it depends on options you choise.
denizen is offline   Reply With Quote
Old   April 20, 2010, 17:55
Jade M is on a distinguished road
Under "Meshing Requirements for DES," the manual states "The grid resolution requirement in the attached boundary layers is the same as that of a regular RANS solution (10-15 nodes in the boundary layer). In the DES region, the grid has to be designed in all three space dimensions to allow at least the resolution of the largest turbulent structures. As the largest grid spacing is used in the switch for the DES limiter, it is essential to have sufficient resolution in the spanwise direction (if it exists)."
Nothing is mentioned about y+. I would suspect that it shows up in the results for informational purposes or left over from RANS but that it's not critical? I'm not expert though.
Jade M is offline   Reply With Quote
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
Ensight - node values -cell values leo FLUENT 1 May 12, 2010 08:47
max node values exceed max element values in contour plot jason_t FLUENT 0 August 19, 2009 11:32
exact face values RubenG Main CFD Forum 0 June 22, 2009 11:09
strange node values @ solid/fluid interface - help JB FLUENT 2 November 1, 2008 12:04
