3D-wind turbine
Old   October 4, 2007, 12:15
Default 3D-wind turbine
Khaled
Is it possible to use MRF in a zone which contain a wind turbine? The rotor of the wind turbine is model as a presure jump (Fan Model)? Thank you for helping me
Est-il possible d'utiliser le MRF dans une zone où un rotor de turbine éolienne est modélisé par un disque où une difference de pression est appliquée(Fan model)? Merci pour l'aide Khaled
Old   October 8, 2007, 06:10
Default Re: 3D-wind turbine
Jones
For turbine, you could analyze the turbine at stationary condition no moving at all, inlet boundary could far velocity inlet or pressure inlet with outlet as out flow or pressure outlet. After applied condition and iteration and ofcourse convergen solution, then u can pick the torsion distribution around blade, and from that you can find typically rpm of your turbine using corelation torsion to blade inertia.
I hope that can help
Old   April 22, 2010, 22:47
yashwant
saini.yashwant is on a distinguished road
Originally Posted by Jones
;145995
sir i am student of M.tech at NIT surat. i am doing numerical simulation of wind turbine by fluent. so i am facing some problems with defining the boundary conditions. so wl u please help me regarding boundary conditions.sir i have modeled wind turbine in gambit and meshed it with two domain interior domain with .5d same as wind radius. and another one is off bigger domain of 4d in diameter. and 3d in front and 5d in back. i have defined the interface in between the surfaces of interior and outer domain. by giving the condition of rotor stationary and the near by domain air is rotating i am getting the axial velocity at the rotor plane more than inlet velocity. is this correct or not. and please help me out how to calculate the power output and coefficient of power.
thanks
saini.yashwant is offline   Reply With Quote
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Wind Turbine - Rotation of the Baldes moonomid CFX 32 March 18, 2016 19:34
Ducted wind turbine (BC for the shroud) Pepita CFX 4 June 29, 2013 07:09
FSI - Wind Turbine AUN CFX 13 August 29, 2012 16:44
Wind turbine simulation Saturn FLUENT 1 June 16, 2006 02:12
