April 28, 2010, 12:05 |
create a probe with fluent
dear all,
I want to create a probe in fluent to assess the temperature field. In fact, i have an experimental profil of the temperature field that I want to compare to the results given by fluent. Unfortunately, the probes used to do the mesures are not protected from radiation. So, my idea is to create a probe in the domain of calculation to see its temperature and compare it to the one given by the experiment. I have tried to do this by making a cylinder, but without sucess beacause this method demand to give a bounadary condition to this cylinder. Does some know a better idea to achieve my comparaion or a better suggestion to create the probe. Regards Aenseeiht |
April 29, 2010, 01:07 |
Maxime Perelli
Rep Power: 41 |
create a point or a rake in fluent, and monitor your results on those entities
In memory of my friend Hervé: CFD engineer & freerider |
April 29, 2010, 03:25 |
Thank you mAx for tour suggestion,
The probleme with you suggestion is that i cant not incule the radiation on the probe. In fact |
April 29, 2010, 03:27 |
Thank you mAx for your suggestion,
The probleme with you suggestion is that i cant not incule the radiation on the probe. In fact i need to inculde it on the prob beacause the probes used to do the mesures were not protected from the radiation. Regards Aenseeiht |
Parallel fluent not using all processors specified | Paul | FLUENT | 18 | October 26, 2023 03:54 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
How to create non-uniform velocity profile in FLUENT? | pankaj | FLUENT | 7 | October 24, 2016 04:52 |
how can I create a curved line in Fluent | antonietta paulozza | FLUENT | 3 | December 25, 2010 02:40 |
Fluent equation error?!? | TOM | FLUENT | 6 | July 15, 2002 03:24 |
