June 16, 2010, 08:25 |
Parameters of 3D high Re flow
Tomasz Merda
Rep Power: 15 |
Hi. I am new in that forum. I am student of Military University of Technology (WAT) in Warsaw. I use Fluent 6.2 (WAT license) to my thesis. I modeling flying of artillery munition. I have 10-15% diffrences between Fluent solution and real values. Because I want to compare some thinks with small differences i should have better accuracy. In my flows speed is between 0,6-3Ma and Re numbers 11000000-60000000 (sometimes higher). I use k-omega SST viscout model and set viscout intensity and turbulent viscosity ratio using formulas
Y+ parameter value is between 40-60 but decresing don't change solution. How can I have more accurate solution? P.S. Please use quite simply english |
High speed flow problems | Sawa | FLUENT | 3 | January 14, 2003 01:10 |
Segregated vs Coupled, High Mach number flow? | David Shkval | FLUENT | 2 | April 14, 2002 07:30 |
High Reynolds Number Incompressible Flow | Nick Lavery | Main CFD Forum | 3 | February 19, 2002 15:47 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
"The high Reynolds number flow is not difficult to compute, the problem is we simply don't know how. | wowakai | Main CFD Forum | 1 | November 11, 1998 10:24 |
