Deforming mesh in fluent
Like Tree2Likes
Old   July 4, 2010, 09:38
Default Deforming mesh in fluent
Hari Prasad is on a distinguished road
My problem is as follows. A deformable container with a minute opening contains fluid. When the walls are compressed the fluid should be forced through the opening. Suggest me suitable methods involving deforming meshes and using user defined functions for the same using Fluent.
Hari Prasad is offline   Reply With Quote
Old   July 4, 2010, 20:45
Jemyung Cha
jemyungcha is on a distinguished road
I think deformable problem can be solved with dynamic mesh module in fluent.
and I have a presentation material including introduction and tutorial.
Let me know your email address. I can send pdf file to you.
jemyungcha is offline   Reply With Quote
Old   July 5, 2010, 13:54
Thanks a lot Jemyungcha. My e mail: hari1041988@yahoo.com
Old   September 27, 2010, 10:47
Default i need too
Rory Helto
roryhelto is on a distinguished road
please send to my email roryhelto@gmail.com
roryhelto is offline   Reply With Quote
Old   September 27, 2010, 11:13
Neil
Trev is on a distinguished road
Depends on the geometry of the container. For example if it is a cylinder like a can you could apply a sinusoidal deforming profile along the cylinder walls like crushing the can in your hand for which I would say take a look at the 2D tutorial which has a flexible oscillating membrane from which you can adapt the UDF to 3D. Or if it is being deformed axially like treading on the can with your foot take a look at the 3D tutorial for the in-cylinder model which describes piston movement. Most likely whatever you are doing you will need to be using a tetrahedral mesh using the spring analogy and smoothing but you will get a better idea if you have a look at the afore mentioned tutorials.
Neil
Trev is offline   Reply With Quote
Old   December 7, 2010, 13:58
Neil Duffy
neilduffy1024 is on a distinguished road
Jemyungcha and Trev, would you both be able to send me the files you mentioned. I have Fluent 12 and the deformation tutorial covers rigid body motion only - the users guide isn't much better. Much appreciated.
Neil
neilduffy1024 is offline   Reply With Quote
Old   December 7, 2010, 18:34
lehoang_mai's Avatar
User_CFD
lehoang_mai is on a distinguished road
Hello guys! Can you send files me too. My e-mail: go_the_way_06@yahoo.com
lehoang_mai is offline   Reply With Quote
Old   December 8, 2010, 02:15
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Send me plz,,
huget_teguh@ymail.com
Now Or Never!!!
teguhtf is offline   Reply With Quote
Old   December 9, 2010, 18:50
hamid
hamid1 is on a distinguished road
Hi
would you send it to me as well, will be very interesting for me,
emruz246@yahoo.com
hamid1 is offline   Reply With Quote
Old   April 5, 2011, 18:20
hun
hung is on a distinguished road
hi
Could you please upload it to mediafile or somewhere.
so every one can download it.
thanks
hung
hung is offline   Reply With Quote
Old   April 6, 2011, 13:53
samt
tumble is on a distinguished road
Hi Jemyungcha
mah0809@gmail.com
tumble is offline   Reply With Quote
Old   May 1, 2011, 23:45
刘小红
LXH029803 is on a distinguished road
LXH029803@YAHOO.COM.CN thank YOU
LXH029803 is offline   Reply With Quote
Old   May 15, 2012, 06:40
Michal
michalRS is on a distinguished road
Hello
I'm joining the request for tutorial/introduction files for deforming mesh. If anyone can shed some light on this problem it will be a great help.
Thank you
michalRS is offline   Reply With Quote
Old   June 26, 2012, 11:20
Default Deforming mesh in FLUENT
  #14
Ajinkya Desai
jinks is on a distinguished road
I have an oscillating fin in FLUENT. It keeps giving me a negative volume error.
1. In the computational setup, the fin is assigned the UDF for oscillation and I have set the default interior as a dynamic deforming mesh. Is this correct?
2. Remeshing and smoothing have been used, with a spring constant factor of 0.5 for the fin faces and the default interior. Apart from these, should any other faces be remeshed?
Thank you.
jinks is offline   Reply With Quote
Old   June 27, 2012, 02:06
Michal
I had a similar solution. It was solved when I changed the smoothing scheme to "diffusion" (0.9).
you can also try using a smaller time step.
Old   June 28, 2012, 22:47
Ajinkya Desai
Thanks, but the problem was solved. I shud not have used default interior for deforming, rather its the domain name.
Thanks anyway.
Old   June 29, 2012, 02:23
VLKOH
lalula2 is on a distinguished road
Can you send me the pdf file too?
Thanks.
My email is kohvoonli@gmail.com
lalula2 is offline   Reply With Quote
Old   June 30, 2012, 11:48
tmeysam92
tmeysam92 is on a distinguished road
Hi all,
i,m working on dynamic mesh.
please send me the same file to me please!!!!
tmeysam92@yahoo.com
tmeysam92 is offline   Reply With Quote
Old   July 1, 2012, 02:19
Michal
I don't think the file really exists. I found the UDF manual pretty helpful (I took the example they used for deforming mesh, and changed it according to my needs). good luck
jinks likes this.
Old   July 1, 2012, 13:09
Ajinkya Desai
For those of you looking for the pdf file for User Defined Functions here is the link...
http://www.hipecc.wichita.edu/pdfs/fludf.pdf
siefdi likes this.
Fluent dynamic mesh 'remeshing' method for pyramid elements DarrenC FLUENT 14 December 11, 2015 04:58
Transport mesh from ICEM CFD, to Fluent, to Sysnoise Wieland FLUENT 2 April 15, 2012 06:28
Exporting structured mesh from ICEMCFD to Fluent? jeevan kumar FLUENT 1 January 23, 2012 11:21
How to use Catia's mesh in Fluent Renaud FLUENT 0 May 31, 2006 07:50
How to convert STAR mesh into FLUENT mesh ? Jihwan Siemens 8 November 10, 2004 04:11
