segmentation violation: define on demand
Old   August 2, 2010, 08:23
Default segmentation violation: define on demand
Sarah
spring is on a distinguished road
Hey guys,
I have a problem with reading data into a variable with a define_on_demand UDF. The error message that I get when I try to "execute it on demand" is the following one:
Stack backtrace generated for process id 26263 on signal 1 :
/ansys_inc/v121/fluent/fluent12.1.2/lnamd64/3ddp/fluent.12.1.2[0x12c759d]
/ansys_inc/v121/fluent/fluent12.1.2/lnamd64/3ddp/fluent.12.1.2[0x12c7aa3]
/lib64/libpthread.so.0[0x3a5400e930]
/lib64/libc.so.6(_IO_vfscanf+0x64)[0x3a53453634]
/lib64/libc.so.6(fscanf+0x88)[0x3a5345ee28]
libudf/lnamd64/3ddp/libudf.so(field_data+0x75)[0x2b4fada7b469]
Check the file fluenterror.log for details.
Please include this information with any bug report you file on this issue!
Error: fluent.12.1.2 received a fatal signal (SEGMENTATION VIOLATION).
Error Object: #f
In an another thread with nearly the same problem I read, that the problem was solved by increasing the variable where the values should be saved. So when I did the same it worked, then the next day it didn't work then it worked and after that it didn't work, didn't work, didn't work......I am really confused because I didn't change anything in my UDF. It seems that Fluent is acting very arbitrarily. Does anybody of you understand the error message and can tell me what it means.
Thanx in advance!
regards,
spring
spring is offline   Reply With Quote
Old   July 27, 2012, 13:37
mila_oliv is on a distinguished road
hey Spring,
by this time you've already solved your problem, i imagine....
I'm receiving this message too, can you tell me where was this information that helped you once?
thanks!
mila_oliv is offline   Reply With Quote
DPM UDF - Segmentation Violation & Stack Backtrace Prashanth Fluent UDF and Scheme Programming 4 July 10, 2012 10:39
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 09:23
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
UDF FOR UNSTEADY TIME STEP mayur FLUENT 3 August 9, 2006 10:19
