Rotor / Stator : Modeling flows with rotating reference frame
Old   November 23, 2010, 18:07
Default Rotor / Stator : Modeling flows with rotating reference frame
Benjamin
Benjikos is on a distinguished road
Hi everyone!
I try to model the rotation of a cylinder (with roughness:look at the attached picture) inside another cylinder (smooth et non rotating) with the purpose of extracting a frequency spectrum of static pressure on the non rotating cylinder wall.
My simulation is 2D and unsteady to record the static pressure change.
The record probe will be at a fixed point on the stator wall.
I would like to know which model is the most accurate in this case (SRF, MRF, MPM ou SMM) ?
Best regards!
Benjamin
Benjikos is offline   Reply With Quote
Old   November 24, 2010, 01:49
siri is on a distinguished road
is this a cfd problem ? is there fluid in the annular region ? how is frequency spectrum analysis relevant to flow simulation ?
siri is offline   Reply With Quote
Old   November 24, 2010, 03:25
Benjamin
Yes it's a CFD problem, there is a fluid annular region between cylinders.
It's a frequency spectrum (static pressure) generated by the rotation of 'steps' (on the rotor) in the annular region.
Old   November 24, 2010, 10:04
Benjamin
Another view of the geometry.
I try to record the unsteady pressure signal on the outer cylinder (fixed).
Old   November 25, 2010, 10:35
Benjamin
Nobody knows how to use the Sliding mesh Model in Fluent? What's the methodology?
how to treat the rotating zone in multiple reference frame (MRF) Jiuan FLUENT 4 May 24, 2010 21:58
question about governing equation in CFX using rotating/non rotating reference frame rystokes CFX 0 January 12, 2010 06:14
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
