Cryosurgery - temperature distribution problem
Old   March 5, 2007, 04:15
Default Cryosurgery - temperature distribution problem
Tal
Hi Guys,
Im working on a project that involves Cryosurgery, which is a way to ablate tumors using extreme cold conditions. An iceball is formed within the body and it engolfs the tumor by "killing" its cells. I need to model the temperature distribution within this iceball as a function of time. I want to create a model that will simulate a human tissue (I already have the thermal properties of the tissue) and to define the initial temperature of the tissue to be 37 degrees centigrade. Inside this tissue I want to define a single point that will have a constant temperature (-100 degrees centigrade). The formation of the iceball starts from this point.
I have some problems in defining these initial conditions using the fluent software, and would like to get some advise from U guys.
Cheers, Tal
Old   March 12, 2007, 04:35
Default Re: Cryosurgery - temperature distribution problem
Rijo Thomas
hai, I am Mtech graduate in Cryogenic Engineering and now I would like to do my Ph.D work in "Heat transfer during Cryosurgery". Can you tell me about your knowledge base and your objective in this area Thanks Rijo
Old   March 15, 2007, 03:07
Tal
Can U B more specific, want exactely would U like to know?
Old   October 18, 2010, 15:58
Guest is on a distinguished road
Hai Mr.Tal,
I am also working on cryotherapy in Fluent. I would like to know whether you solve your problem or not? I need a suggestion from you regarding that.
Thankyou.
Guest is offline   Reply With Quote
unsteady temperature distribution over coupled bc in MultiRegionCase mvoss OpenFOAM Running, Solving & CFD 0 December 29, 2010 05:17
Temperature distribution at Impeller core!> CFDtoy Main CFD Forum 5 May 14, 2007 09:06
Temperature local distribution on the boundary Matteo Siemens 0 January 10, 2007 07:18
Problem with transport properties depending on Temperature galaad OpenFOAM Running, Solving & CFD 5 December 6, 2005 12:51
Linear Temperature Distribution Kathir FLUENT 0 July 16, 2004 09:33
