problem in VOF
Old   November 22, 2010, 10:26
Default problem in VOF
hamid
hamid1 is on a distinguished road
I am going to simulate a two phase flow through VOF in fluent, now the problem is after simulation ending when I see the domain there is like the second phase didnt move at all, I tried for different B.C. but still there is no difference
hamid1 is offline   Reply With Quote
Old   November 22, 2010, 13:40
Guiliguili
Touré is on a distinguished road
Check at Run Calculation your Time Step Size or your Number of Time Steps. It should be different of 0.
Touré is offline   Reply With Quote
Old   November 23, 2010, 12:39
hamid
thanks Toure, it was my post processing problem, seems to be okaid now, thanks again
Old   February 3, 2011, 17:12
daalou
alilouu is on a distinguished road
same robleme, but not the solution, in the end of calculatiing, i find always one phse, knowing that before u used two phases (air + benzene)
thanks
alilouu is offline   Reply With Quote
Old   February 4, 2011, 08:34
hamid
did u patch the second phase?
Old   February 4, 2011, 09:09
kbaker's Avatar
Khalid Baker
kbaker is on a distinguished road
Hamid did you use two inlets or single inlet? do u have a pipe flow?
kbaker is offline   Reply With Quote
Old   February 4, 2011, 10:38
hamid
mine are two pipes inside each other while the inner pipe will suck the fluid moving inside the outer pipe,let say one inlet and two outlet, kind of ..., just reminding u, after adapt region u v to patch in initialize menu the second phase, also in before u have to set the second phase like o at inlet ...
Old   February 5, 2011, 00:32
kbaker's Avatar
Khalid Baker
You mean that you have annuls?
Two-phase VOF problem scott copland FLUENT 3 March 15, 2007 07:25
Free CFD solver for VOF problem Jan Main CFD Forum 1 October 30, 2006 10:15
Problem with VOF open channel modelling Biswanath Mahato FLUENT 1 September 14, 2006 04:20
A Problem with setting the time step in VOF model Le FLUENT 2 July 20, 2006 22:00
problem with VOF. Marc FLUENT 1 June 5, 2002 08:17
