Unexpected difference between velocity / mass-flow inlet |
December 7, 2010, 22:47 |
Rep Power: 17 |
I am modeling a 3D incompressible inviscid airflow in a system. It has 1 velocity inlet and a number of outflow outlets. It converges fine. Then I check the mass flux via inlet: let's say it is M_dot and switch velocity inlet to mass-flow inlet, request a flux equal to M_dot. Case loses convergence right away and can't converge properly anymore. I don't understand why. Nothing really has changed, except the inlet type. Where am I going wrong? Thank you for your thoughts. |
December 9, 2010, 01:10 |
Maxime Perelli
Rep Power: 41 |
try to switch from outflow to pressure outlet.
I always heard that combination velocity-inlet / pressure-outlet was more stable than mass-flow-inlet / pressure-outlet. Don't ask me why...
In memory of my friend Hervé: CFD engineer & freerider |
December 9, 2010, 06:17 |
Rep Power: 17 |
-mAx-, thank you for your reply and for the time you dedicate in helping others in this forum
I tried this, but there is a problem. How do I set the pressures? My goal is to switch the whole thing to compressible flow. But velocity inlet/outflows do not work with pressure. I cannot make the transition... |
December 9, 2010, 07:44 |
Maxime Perelli
Rep Power: 41 |
I don't understand what you mean with transition.
Set your outlet with Pressure-Outlet Boundary Condition. Set your pressure with 0 Pa (outlet free)
December 9, 2010, 07:49 |
Rep Power: 17 |
My system has a number of outlets. Compressible simulation is hard to converge. This is why I do incompressible first and try to find out the pressures on all terminals.
Once this is done, I can retry running compressible calculation with the new pressures. |
December 9, 2010, 09:37 |
Maxime Perelli
Rep Power: 41 |
So you have number of outlets, but you don't know neither their pressure, nor their massfow?
December 9, 2010, 10:42 |
Rep Power: 17 |
that is correct
I only know their approximate massflow percentages (e.g. parts of the mass entering the system) |
December 10, 2010, 01:27 |
Maxime Perelli
Rep Power: 41 |
then try to work with pressure-outlet and enable target massflow option, with giving approximate massflow
December 10, 2010, 07:20 |
#9 |
Rep Power: 17 |
to be honest, whenever I have tried enabling target mass flow on pressure outlets, it hardly ever works
It didn't work in this case either But it works with velocity inlet/outflow exits. I am trying to figure out how to use this successful calculation and set up the exits as pressure outlets |
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 04:58 |
Inlet Velocity in CFX | aeroman | CFX | 12 | August 6, 2009 18:42 |
velocity or mass flow inlet? | Silvia | FLUENT | 1 | August 12, 2005 13:55 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
Can reversed flow occur at velocity inlet Bcs. | kanok | FLUENT | 1 | September 30, 2003 11:54 |
