reversed flow
Old   December 11, 2010, 15:27
Default reversed flow
Mohammad
nouri67 is on a distinguished road
hi
What is the meaning "reversed flow" and how to prevent it?
Thanks
nouri67 is offline   Reply With Quote
Old   December 12, 2010, 01:21
xrs333
xrs333 is on a distinguished road
A "Reversw Flow" message indicates you that the fluid flows in wrong direction at the flow boundaries, for example, flowing into the domain through an outlet occurs where the flow is expected out of the domain.
This occurs as often the case when the outlet boundary is ill posed.
xrs333 is offline   Reply With Quote
Old   December 12, 2010, 12:01
Mohammad
I put the boundary conditions OUT FLOW
One issue is that flow in a vertical tube that has gravity rises and after bending 90 degrees pours out
Remove the solution gives reversed out flow
Thanks your answer
reversed flow free FLUENT 4 February 27, 2014 02:56
reversed flow during RNG in turbulence-k epsilon Suman Kandula FLUENT 4 April 2, 2012 08:12
Reversed flow...>>>Please HELP...! sushii FLUENT 14 October 29, 2007 05:27
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 14:11
reversed flow Sastry FLUENT 5 March 22, 2007 09:05
