February 3, 2011, 08:42 |
compiling udf at window Nt(64BIT)
anonymous
I am working on windows NT 6.1 (64bit) at Ansys 13. I can't compile my udf
1. I followed the following instructions: How can I manage to compile my UDF with Windows 7 64bit? How can I manage to compile my UDF with Windows 7 64bit?
2. I verified the path is right and changed it to: Microsoft Visual Studio 9.0 and to v 130. 3. I could start Fluent from the SDK prompt. 4. When I compiled the c file, there were no errors. 5. When I loaded the file I got the following message > 1 file(s) copied. (system "copy "C:\PROGRA~1\ANSYSI~1\v130\fluent"\fluent13.0. 0\sr c\makefile_nt.udf "libudf\win64\2d\makefile" ") 1 file(s) copied. (chdir "libudf")() (chdir "win64\2d")() # Generating ud_io1.h Done. Opening library "D:\sarit\tut6_files\dp0\FFF\Fluent\libudf"... Error: The UDF library you are trying to load (libudf) is not compiled for 2d on the curent platform (win64). The system cannot find the file specified. D:\sarit ut6_files\dp0\FFF\Fluent\libudf\win64\2d\libudf.dl l Error Object: #f What to do? |
July 15, 2011, 04:45 |
solution found??
Hello noa,
I am having exactly the same problem. Have you found a solution? I would really appreciate it, if you can give me tips how you solved your problem. Regards |
July 19, 2011, 13:14 |
Hi
I am facing the same problem too, any updates on the situation?
July 29, 2014, 23:01 |
Thiagu
If it is windows-7 and 64 bit system, then enable "virtualization" option
restart the system, Press del or F10 --> BIOS -->options or advanced option --> Hope this may work.. then compile and check |
About UDF compiling issues: 'nmake' | Haoyin Shan | Fluent UDF and Scheme Programming | 15 | November 4, 2019 18:05 |
compiling linked udf (C/fortran mixed) | bawfuls | Fluent UDF and Scheme Programming | 0 | July 13, 2010 16:53 |
UDF compiling problem in Flient 6.3 | jeevan kumar | FLUENT | 2 | February 25, 2009 00:43 |
udf compiling problem | akr | FLUENT | 3 | August 22, 2007 07:14 |
On Compiling a UDF | David Chabot | FLUENT | 5 | May 20, 2005 09:13 |
