Problem in enabling buoyancy
Old   March 9, 2011, 09:40
Default Problem in enabling buoyancy
hma11 is on a distinguished road
Hi guys,
I'm not entirely new to Fluent but I have been working on it and I faced some problems.
How can I enable the buoyancy for a case?
I created a closed domain which represent a resrvoir of fluid and I tried to enable buoyancy to see the effects of natural convection on the temperatur distribution but with no success. Firstly, I enabled gravity in operating conditions and set the acceleration in the y-direction to -9.81. Secondly, I used Boussinesq Model for determing the density of the fluid which is water.
Conclusion, I can't see any variation in temperature between the bottom and the surface of the reservoir.
What I am doing wrong?
Thank you in advance.
hma11 is offline   Reply With Quote
Old   March 12, 2011, 07:38
xrs333
xrs333 is on a distinguished road
what thermal boundary conditions have you define?
xrs333 is offline   Reply With Quote
Old   March 12, 2011, 08:30
I set the bottom wall to a temperature of 280K then for the top wall I tried 300k then heat flux of 1000,2000,3000 all gave same result
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
static temperature is higher than total temp. in buoyancy problem amirbahador FLUENT 2 October 24, 2010 07:21
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Converging problem of buoyancy flow Cadrian FLUENT 4 January 19, 2007 17:09
