k-e convergence criteria
Old   May 19, 2011, 23:53
Default k-e convergence criteria
araz
aras is on a distinguished road
I am solving a turbulence flow inside a pipe with many steps, complexities including lots of walls.
I am getting good convergence (below 1e-3) for velocities, and continuity.
but k and e are fluctuating in the range of 1e-2, is it ok? and generally what is the satisfactory range of convergence for k and e?
thx
aras is offline   Reply With Quote
Old   May 20, 2011, 06:29
alastormoody11 is on a distinguished road
Have you checked the validity of your mesh for using the k-e model, check whether the wall y plus values are in accordance with the recommended values suggested in the FLUENT manual.
I think the default values for the residuals are good enough. I would not recommend that you use unconverged results.
alastormoody11 is offline   Reply With Quote
Old   May 20, 2011, 08:53
araz
so, do you know what are the recommended y+ in fluent for k-e?
Old   May 21, 2011, 08:44
David Stanbridge
swiftaircraft is on a distinguished road
This is clearly specified in the help files provided with Fluent
swiftaircraft is offline   Reply With Quote
convergence, kinetic energy, residuals
What value shall I set for the Convergence criteria? steventay CFX 7 May 14, 2010 12:44
Convergence criteria PrandtlGlawert FLUENT 1 August 13, 2009 18:06
Convergence criteria PrandtlGlawert Main CFD Forum 1 August 13, 2009 17:13
Convergence Criteria edwin FLUENT 1 February 14, 2008 19:24
Global Convergence Criteria asaha OpenFOAM Running, Solving & CFD 0 December 9, 2007 09:53
