how to solve a problem involving both laminar and turbulent flow |
June 2, 2011, 12:44 |
hi..im trying to solve a double tube heat exchanger problem and validate it with the experimental value in which the flow inside inner tube (hot water) is turbulent and the flow in the outer tube (cold water) is laminar
so in the "viscous" tab in defining models, which option should i select; whether laminar or k epsilon?? i tried solving it considering it as turbulent as a whole and selected k epsilon, but on doing so the outlet cold temperature went beyond the value of outlet hot temperature by some decimals...why is it so???? but the value of the outlet hot temperature was comparable with the experimental...why is this happening?? also i tried solving it as fully laminar, but now the cold outlet temperature was exactly same to the experimental but the hot outlet temperature was much higher than the real hot outlet temperature. why this happens?? please help also please tell how can i solve such a problem quite accurately.... please post and help.. thanking in advance..... |
June 3, 2011, 03:20 |
Hey,
you can set specific zone in FLUENT as laminar zone when the solver is set as k-epsilon for example. define->BC->fluid zone->.... toggle on laminar zone in such problems (heat transfer) it's better to use node based gradients. |
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 07:08 |
Can I use turbulent model to solve a laminar flow? | nikhil | FLUENT | 5 | February 1, 2011 10:42 |
Laminar flow or Turbulent flow | mech | FLUENT | 0 | January 27, 2007 18:51 |
laminar and turbulent flow in one simulation | msna | FLUENT | 0 | January 27, 2007 17:35 |
modelling laminar and turbulent flow in the same | Ol | FLUENT | 2 | November 25, 2005 02:52 |
