Saving velocity field and reading it back for another case |
June 10, 2011, 00:43 |
Pranab N Jha
I want to capture the velocity field in single phase flow for a domain and then use it for initializing my multiphase flow in the same domain. How can this be achieved? Is there a way to capture the vectors (or velocity data in any form) and write some type of data file that can be read back when I start my multiphase solver?
I found this thread, but no-one seemed to have an answer then? Can anyone help me now? http://www.cfd-online.com/Forums/flu...hase-flow.html Thanks, Pranab |
June 13, 2011, 09:42 |
Pranab N Jha
This question was asked by another gentleman a few years back too, but seems no-one had an answer. Well, I asked one of my colleagues in the lab here, and he had a very good suggestion to make.
To get the velocity/pressure data at every node from a steady state or a single phase case, write it as an "Interpolation file" with the extension [.ip] once you have your solution. Then you can read this .ip file back into your two-phase flow field after you initialize your flow field, so that now you have initialized the domain with a velocity field from the steady state itself. This will give better and quicker convergence in unsteady case. Hope this is of help to someone. Cheers! |
September 1, 2023, 01:44 |
Yakub
Rep Power: 3 |
its was helpful even none answered, you given the solution.thanks
multiphase, velocity field. |
Cht tutorial in 15 | braennstroem | OpenFOAM Running, Solving & CFD | 197 | June 10, 2015 03:02 |
solid to fluid heattransfer with chtMultiRegionFoam | nakor | OpenFOAM | 11 | March 21, 2011 08:28 |
Reading field values and setting them as boundary conditions | sega | OpenFOAM Running, Solving & CFD | 1 | July 7, 2009 06:18 |
[Commercial meshers] TGridFluent mesh with internal by prism layer and internal face for diagnostic | sponiar | OpenFOAM Meshing & Mesh Conversion | 2 | March 30, 2009 15:02 |
