Jack
Rep Power: 16 ![]() |
Dear all,
Please take a look at the attached picture. You will see that the streamtraces (generated by TecPlot) are impinging on the wall and they disappear which is not physical. After they impinge on the wall, they should move to another direction, not disappear. It is like they pass through the wall. What do u think about that? do u think it is a computational error and should I try to change my solution? or it has a meaning that I do not know? Thanks. |
nat
Rep Power: 0 ![]() |
hello there!
i'm facing the same issues on CFD-Post. I recently upgraded to ANSYS 13.0 and I start to have discontinuous streamlines that stops on the solid faces. Whatīs the problem? If I open a run done on ANSYS 12.1 itīs ok. Thanks! |
stremaline |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
