August 1, 2011, 13:40 |
Help! Which solver should I use?
Tom
Rep Power: 14 |
Hi, I am simulating a foil shaped fairing moving through seawater. Which type of solver should I use? Pressure or density based? I am pretty new to CFD so any advice or explanations of these solvers would help me out a lot.
Thanks Tom |
August 2, 2011, 04:37 |
Charles
Rep Power: 14 |
You can search in the Fluent help, you'll find some pretty comprehensive explanations about the solvers.
August 2, 2011, 04:42 |
Charles
Rep Power: 14 |
August 2, 2011, 05:16 |
Rep Power: 14 |
Hi Tom,
It depends on your flow characteristics. Normally you would use pressure based for incompressible flow and density based for compressible flow. Assuming you have incompressible flow you could use the pressure based solver. Sincerely, A.D.E |
August 2, 2011, 07:03 |
Tom
Rep Power: 14 |
Thankyou this is all very helpful
Tom |
A New Solver for Supersonic Combustion | nakul | OpenFOAM Announcements from Other Sources | 19 | February 27, 2024 09:44 |
[Other] A New Solver for Supersonic Combustion | nakul | OpenFOAM Community Contributions | 20 | February 22, 2019 09:08 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
Development of a Low mach PISO solver | nishant_hull | OpenFOAM Programming & Development | 0 | August 25, 2009 12:48 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
