September 14, 2011, 02:47 |
modeling solids feeding to air flow
Angie
Hi Guys,
My case is the gravity feeding of solids from a cylindrical container (Height ,h)to air flow inside a pipe. How can i model this in fluent. I want to find out the velocity profiles of the solids . What boundary conditions should I use. Initially the solids are at rest and when the valve is opened , solids fall due to gravity to gas flow. Someone kindly help me. |
September 14, 2011, 12:01 |
Harpreet
try using DPM model, and activate gravity in operting conditions along the direction of flow desired.
September 15, 2011, 01:14 |
Angie
Thanks Harpreet for your reply. But what about the boundary conditions.what will be the initial velocity of solids.
September 15, 2011, 12:48 |
Harpreet
although i haven't tried, but i think if you could the unsteady case with initial velocity of solid particles set to zero, it should work. For the boundry conditions more description of your problem is required.
Simulation of air flow in a chamber | Issa | CFX | 3 | November 23, 2009 17:16 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
3D-Simulation of Water Flow From Nozzle into Air | Navin Sampath | FLOW-3D | 2 | February 26, 2009 10:46 |
mold flow modeling | Pei Hsieh | Main CFD Forum | 0 | May 4, 2005 10:08 |
Increasing air flow using fans | jim sanders | FLUENT | 0 | January 10, 2002 09:24 |
