periodic boundary conditions
Like Tree1Likes
  • 1 Post By oj.bulmer
Old   March 26, 2013, 23:45
Default periodic boundary conditions
Naguluru prashanth kumar.
bob2cool is on a distinguished road
what is the actual significance of periodic boundary conditions(especially in problems pertaining to flow over a cylinder)? how do we create them?
bob2cool is offline   Reply With Quote
Old   March 27, 2013, 07:16
OJ
oj.bulmer will become famous soon enough
The periodic boundary conditions are used to simulate repeated patterns of geometry. There are two types of periodic boundaries.
a) Allowing pressure drop: In this case there is a definite pressure drop across the periodic boundary, typically in streamwise direction and hence it is also called as streamwise periodic.
b) Not allowing pressure drop: In this case there is no pressure drop across the boundary and also called as translational periodic. The same is called as rotational periodic if you are simulating a cylindrical wedge and specifying the cut sections of wedge as periodic boundaries.
This is very well covered in the documentation, have you had a look at it?
OJ
jthiakz likes this.
oj.bulmer is offline   Reply With Quote
ribbed channel / simpleFoam / boundary conditions beeo OpenFOAM Pre-Processing 20 July 17, 2013 08:39
periodic boundary conditions fro pressure Salem Main CFD Forum 21 April 10, 2013 00:44
Periodic boundary conditions in 3D Eulerian granular flow simulations dsm FLUENT 4 March 2, 2012 19:04
periodic boundary conditions mranji1 Main CFD Forum 4 August 24, 2009 23:45
