Effect of gradient scheme on Nusselt Number
Old   February 13, 2017, 03:04
Default Effect of gradient scheme on Nusselt Number
Saurav Kumar
srv537 is on a distinguished road
i am simulating laminar flow with heat transfer in a duct and i am using structure type of mesh.
i used solve/set/expert to get Temperature gradient and based on that i defined local Nusselt Number.
the problem is when i changed the gradient schemes from Green-Gauss cell based to Green-Gauss node based then Averaged Nusselt number (Area Weighted Average ) changed by 15% but there is no change in local nusselt number, how is this possible? i am totally confused.
am i doing something wrong? pease suggest me.
Thank you,
Kind Regards,
Srv
srv537 is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 09:12
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 05:35
write out nusselt number (gradient of T, respectively) for timesteps sven OpenFOAM Programming & Development 38 January 2, 2017 04:59
decomposePar -allRegions stru OpenFOAM Pre-Processing 2 August 25, 2015 03:58
[blockMesh] --> foam fatal error: lillo763 OpenFOAM Meshing & Mesh Conversion 0 March 5, 2014 10:27
