November 21, 2011, 13:45 |
Mass Flow Problem
Student_87
Good evening
I am creating mass in my model, and I get very high velocities in the air phase. Anybody that have an idea where the mistake/s could be? Geometry data: Length of model = 10m, width=1m, Inlet area and outlet area = 1.25m^2, height step =0,25m. The geometry is set to be 70% filled with water. Set-up: - Pressure-based, velocity formulation absolute, transient, gravity=-9.81 - VOF, implicit, open channel flow, implicit body force, - k-epsilon, relizable, standard wall functions - Primary phase = air (constant density) and secondary phase = water - Inlet boundary: Multiphase, free surface level -2.14,bottom level -3.015. Air, mass flow rate = 0.045 kg/s Water, mass flow rate = 87,5 kg/s - Outlet boundary: Outflow, flow rate weighting = 1 - Reference values: v=0.1m/s - Solution method: PISO Any help would be appreciated |
November 22, 2011, 11:51 |
Laurent B
What's about your residuals ? Did you achieve convergence ? |
November 22, 2011, 14:07 |
#3 | |
Student_87
Under relaxation factors was set up: Pressure = 0.3 Density = 1 Body Forces = 1 Momentum = 0.5 Volume Fraction = 0.5 Turbulent Kinetic Energy = 0.8 Turbulent Viscosity =1 Thank you for trying to help me |
November 23, 2011, 03:08 |
Laurent B
You must obtain convergence before checking mass imbalance.
Try to iterate more until you obtain convergence |
November 23, 2011, 03:44 |
Student_87
Thanks. I will do some more iteration to try to get convergence, but do you think the under relaxation factors seems reasonable? Is it corect to set this up as a transient problem, or should it have been steady state?
November 23, 2011, 03:57 |
Laurent B
The choice between steady and transient depends on what you want to do, what's the aim of your work ? don't matter about under relaxation factors before you are not sure of what you want to do exactly...
November 23, 2011, 07:48 |
Student_87
I want to see the effect the step has on the flow pattern.
November 23, 2011, 08:21 |
Laurent B
try to use steady state formulation
November 24, 2011, 01:13 |
If it's an open channel flow, the top wall of your model should have a pressure BC of atmosphere
November 24, 2011, 03:54 |
Student_87
combustion problem | mcnair | CFX | 9 | March 22, 2011 14:06 |
Problem of mass conservation in multispecies flow in porous media and T° gradient | pilou | FLUENT | 0 | January 31, 2011 08:19 |
Mass flow and U-Mom flow in CFX | Zhihua Xie | CFX | 0 | September 3, 2007 09:49 |
Mass Flow Rate Conservation Problem | philippe | FLUENT | 8 | May 5, 2003 11:43 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
