influence of specified density in head losses or static pressure
Old   November 22, 2011, 11:59
Default influence of specified density in head losses or static pressure
Juan
Tres is on a distinguished road
Is it possible that Fluent compute directly the head losses and not the static pressure?.
I have made a simulation in a vertical pipe and the difference between two points is the same as the head losses i computed in my laboratory. It happens when choose gravity and specified gravity operation like 0. I imagine It is not right at all, because Fluent computes static presssure but not head losses.
I do not understand how it works the option specified density
Thanks
Tres is offline   Reply With Quote
Old   November 23, 2011, 04:54
Nano_Cryo is on a distinguished road
Hi Tres,
I assume you can achieve that by defining a user function in the Define/Custom_field-function, which allows you to create you own function based on Fluent results, and to use it afterward (plots, data files...). You can then change you change in pressure.
Hope it was of any help!
Cheers,
Nano
Nano_Cryo is offline   Reply With Quote
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 04:24
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 05:08
enum MASOUD Fluent UDF and Scheme Programming 0 June 5, 2010 00:49
negative static pressure Selo melo FLUENT 5 December 18, 2006 09:30
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
