How to export velocitiy of inlet from FLUENT? (3D)
Like Tree1Likes
  • 1 Post By TKE
Old   November 22, 2011, 14:04
Default How to export velocitiy of inlet from FLUENT? (3D)
TKE
TKE's Avatar
Jozsef Rideg
TKE is on a distinguished road
I have a simulation result with FLUENT. I would like to export the velocity field of velocity inlet (rectangular surface).
In 2D I used xy plots, with x=0 y=0 z=1, and with that I could easily define my BC in OpenFOAM as a list.
But in 3D it is not clear, how should I get a list of velocity components of every single cell of inlet surface. I tried with the xy plot option of x=0 y=0 z=1 and x=0 y=1 z=0, but I recived striped pattern as OpenFOAM inlet.
Is there any suggestions how could I get the list of velocity of cells (of inlet BC surface)?
Thank
TKE
p.s.: I was not sure whether this topic is related rather to FLUENT or OpenFOAM. But I have problem with obtaining that list rather then applying it in OF.
TKE is offline   Reply With Quote
Old   November 22, 2011, 18:24
Default Closet thread. :)
TKE
TKE's Avatar
Jozsef Rideg
This is the solution I found out:
Maybe that can be useful for other users as well...
file->export->solution data
-file type: ASCII
-cell center
-quantities: velocity x, y, z
-surface: in
Regards,
TKE
laurentb likes this.
Old   July 9, 2014, 08:38
Default Read the ASCII file back into fluent?
Srivathsan N
Sherlock_1812 is on a distinguished road
Hi Jozeph,
My case is a 2D axisymmetric case where I have a converged velocity field. I do not want to read the file into OpenFOAM but would like to read it back into another case in Fluent. I want to supply the velocity field as an initial condition to the second case.
File -> Import does not have the ASCII option. Do you have an idea how I can do this?
Regards,
Srivaths
Sherlock_1812 is offline   Reply With Quote
boundary condition, fluent, openfoam, velocity profile
Export mesh from Fluent in Nastran format Wieland FLUENT 9 October 19, 2012 09:16
[ANSYS Meshing] Export .msh file for fluent by script Mostapha ANSYS Meshing & Geometry 1 August 2, 2011 05:33
Inlet boundary condition Fluent natantyt FLUENT 0 June 10, 2011 18:20
Validation 12.1 vs 6.3, Difference in Reported Inlet Total Pressure jola FLUENT 1 May 5, 2011 14:33
Fluent Export Command Issue .... Leo Hindarto FLUENT 0 January 3, 2009 23:20
