Regarding Ourlet Boundary Condition
Old   January 12, 2012, 12:01
Default Regarding Ourlet Boundary Condition
G Sivaramakrishna
ksivarama is on a distinguished road
Is it ok to use 'exit static pressure with target mass flow rate' boundary condition for a high subsonic flows (Mn ~ 0.7-0.9)?
ksivarama is offline   Reply With Quote
Old   January 13, 2012, 23:56
Lucky
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
Absolutely. The exit static pressure is a very robust boundary condition and often makes the most physical sense and should be used whenever appropriate.
You may want to guess an exit pressure and run the solver for awhile without enabling the target mass flow rate option. Once the main flow features have settled and the solution has stabilized, then the target mass flow rate option can be turned on. You may have convergence trouble if the target mass flow rate option is turned on from the 1st iteration.
LuckyTran is online now   Reply With Quote
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Can anyone give me some hint on how to make traction free boundary condition? poplar OpenFOAM 3 January 14, 2015 02:37
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 03:23
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
