Local heat transfer coefficient around a cylinder
Like Tree1Likes
  • 1 Post By dal_fry
Old   January 14, 2012, 11:29
Question Local heat transfer coefficient around a cylinder
Benjamin
dal_fry is on a distinguished road
I'm trying to get the local Nusselt number around one cylinder in an external air flow.
(http://siam51.free.fr/air_flow.bmp)
The mesh is fine enough to have y+~1 near the wall.
I got the total temperature near the wall, the heat flux near the wall (W/mē) and the total heat flux exchanged (W)
To calculate the local heat transfer coefficient, I tried two methods :
h1 = [ heat flux near the wall (W/mē) ] / (383-263)
h2 = [ total heat flux exchanged (W) ] / (383-total temperature near the wall)
Values are completely different!
h1~50-450
h2~250-600
I wonder what would be the best formula to use?
Thanks in advance!
elham-u likes this.
dal_fry is offline   Reply With Quote
Old   January 20, 2012, 13:23
mali28 is on a distinguished road
You have to use static temperature in your calculation not the total temperature.
h1~50-450
h2~250-600
Thanks in advance!
mali28 is offline   Reply With Quote
Old   March 29, 2013, 13:35
elham usefi
elham-u is on a distinguished road
h1~50-450
h2~250-600
Thanks in advance!
hi
i have the same problem!
but i have a problem in calculating the local heat transfer around the cylinder!
should i choose some points by surface-point-coordinate?i think cartesian coordinate isn't accurate! plz help me!
thanks in advance!
elham-u is offline   Reply With Quote
heat transfer coefficient as initial value tH3f0rC3 OpenFOAM 9 June 20, 2018 02:45
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade Karkoura CFX 0 March 10, 2011 15:35
heat transfer coefficient? Sima Baheri Phoenics 8 September 2, 2007 01:41
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
heat transfer coefficient ravi FLUENT 0 July 23, 2004 00:08
