Radial turbine problem
Old   January 22, 2012, 05:18
Default Radial turbine problem
ingmecc's Avatar
Giuseppe DiB
ingmecc is on a distinguished road
Hi, i'm new in this matter and so i've some questions.
I'm studing a radial turbine that expands a compressible fluid. Though the pressure at discharge of turbine is less than inlet, both the velocity magnitude and relative velocity magnitude on the outlet are bigger than inlet. Is it possible?I analyze its with fluent.
Thank you so much.
ingmecc is offline   Reply With Quote
Old   January 22, 2012, 11:30
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Relative velocity should increase (converging passage blade-to-blade) and absolute velocity should decrease (work is being done, velocity energy is being converted to work). Ensure that solution is full converged and settings (e.g. rotation direction) are OK
Far is offline   Reply With Quote
Old   January 22, 2012, 18:25
ingmecc's Avatar
Giuseppe DiB
Thank you so much!For convergence i'm testing with steady simplec implicit...step by step increasing inlet total pressure, outlet static pressure and rpm.Is it right??
Old   January 22, 2012, 21:26
Far
Sijal
Put the required values of total pressure at inlet and static pressure at outlet, however, increase rpm in steps.
Direction of Rotation of Radial Turbine ghoshi1983 CFX 8 June 19, 2012 10:16
Convergence of Radial Turbine Simulation Hugh CFX 10 June 30, 2010 08:08
radial turbine flow analysis ME Siemens 1 August 16, 2007 03:06
radial inflow turbine rotor periodicity problem Nanda FLUENT 1 July 17, 2006 14:52
radial inflow turbine rotor periodicity problem Nanda FLUENT 0 July 11, 2006 20:35
