Student in need of help! 2-D airfoil problem
Old   January 31, 2012, 11:14
Default Student in need of help! 2-D airfoil problem
Orion Modebe
orion is on a distinguished road
Hi
I'm currently trying to run a 2D airfoil in fluent to find if there is any significant separation when a small flat plate is attached to the trailing edge. It is a follow up from a wind tunnel experiment, so it is supposed to replicate the airfoil in a wind tunnel.
The problem is that I'm not sure which is the best turbulence model to use, or if I should be using in order to replicate the wind tunnel. I believe it would be best to use either Spalart allmans model or the K-w model but I'm not sure which would be best.
Any advice on which one to use would be much appreciated.
Thanks
orion is offline   Reply With Quote
Old   January 31, 2012, 11:34
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
did you take a look at the tutorial ?? there is a tutorial about airfoil in fluent documentation.
cheers
diamondx is offline   Reply With Quote
Old   February 1, 2012, 11:26
Orion Modebe
cheers
yes i did, but that uses the spalart allmans model. I was hoping for a bit of guidnce in terms of which would be better to be analysing separation and the boundary layer?
Old   February 2, 2012, 16:16
Default I have a model
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
I have a model for airfoial from zero to finish if u need it send a private message
tareqkh is offline   Reply With Quote
Convergence Problem icoFoam steady flow over an airfoil Lucas OpenFOAM Running, Solving & CFD 6 July 12, 2018 15:06
2D SST Simulation Airfoil - Convergence Problem Kraemer CFX 10 April 16, 2011 07:22
Fluid Structure Interaction problem for airfoil vinair39 OpenFOAM 0 February 8, 2011 07:57
Residual problem of 2D airfoil simulation caohan FLUENT 9 April 13, 2010 16:03
airfoil, mesh spacing problem, CFX-ICEM Santiago Orrego. CFX 3 January 14, 2007 18:19
